I had the exact same problem on all 3 of mine
If you Elevator down to a minimum make sure you keep speed under it. it does not do slow at all. Check the lateral CG as well, that will help. move the CG a bit forward too. Only drawback is you will lose some of the snaipness that makes the plane fun
Experiment with this and hope it helps.
matt
