Your formula may be correct, but is good only for comparision among propellers, instead of for the load a prop will put on an engine.
The increment in diameter has a bigger effect on the load than the pitch.
The load increases with the cube of the diameter (D X D X D), and the square of the pitch (P X P).
http://www.hooked-on-rc-airplanes.co...ropellers.html
http://www.ampaviators.com/2007/05/15/propeller-basics/
http://en.wikipedia.org/wiki/Propeller
(Editted to add links)
