ORIGINAL: opjose
Gorish
Unfortunately you are approaching this BACKWARD.
With electrics the prop size determines what the draw, thrust, power requirements, etc. will be.
In turn the prop size used is determined by the plane, weight, and expected levels of performance.
You already have a motor that has a rather high KV rating for props.
The HK/HC web site states that for a 3S LiPo the maximum prop you can use is a 7x4, and an 18A ESC is required.
It also puts the power output ( at max ) of the motor @ 140 watts
Knowing that we can work some things out....
140w / 11.1v = 12.7A max draw
1650kv x 11.1v = 18,315 RPM
18,315 RPM * .8 (to emulate static thrust values ) = 14652 RPM
14652 RPM on a 7x4 prop gives a pitch speed of about 56 MPH and a static thrust around 1.5lbs.
That is quite fast for a small 3D foamy.
A larger prop would overload the motor causing it to overheat and burn out.
This motor is really better suited to a small fast pusher foam jet than it is for your intended plane.
What you want is a higher thrust, lower pitch speed motor for 3D instead.
Hummmmm!! Don't understand a word you said
I guess I will put my 70 4 Stroke on it. I always go after things backwards
Our club has an electric fly this weekend and I don't fly elect. But though I would put this together. Maybe I can find a club member that has a more suited motor for this. Or, maybe I will just go and watch again this year.[sm=sad_smile.gif][sm=sad_smile.gif]
