RCU Forums - View Single Post - Engine Torque Problem
Old 06-03-2010 | 07:40 AM
Iflyglow's Avatar
Iflyglow
My Feedback: (79)
Default RE: Engine Torque Problem
ORIGINAL: DarZeelon
SpaceRockMan,
Torque is the wrong term and this was discussed before you got here.
The problem that caused your crash, is the same as what caused that deadly crash at Oshkosh, a couple of years ago.
It is not torque that causes a plane to veer off its course, during the take-off run; but the prop's spiral slipstream, hitting the fin and the rudder on one side...
Because of ground deflection, with the tail low, hugging the runway; the bottom of the slipstream hits the fin and the rudder from the right, requiring left-rudder to correct.
Once the plane gains some speed and the tail rises, it is the top of slipstream that hits the rudder and the fin; but now from the left! This requires a force reversal, because now right-rudder is required, to keep the plane tracking straight.
This confuses newbies, even to the brink of hurrying the take-off, ground-looping and crashing their model...Or their full-size plane.
I am sorry it had to happen to you.
Extending the take-off run a bit, to achieve greater speed, is the solution.
The P-factor is another issue... When a plane climbs out after take-off, it is at a rather low speed with the nose high.
As a result, the descending blades of the prop have a higher eventual angle of attack, than the prop's rising blades.
As a result the plane tends to veer to the left during climb-out, requiring right-rudder input from the pilot, to fly straight...
Dar,
I live close too Oshkosh, and was there that day. That Mustang crash was caused by two P-51's that were landing at two different speeds. The trailing mustang was a modified P-51 and it was landing much faster "still airborn" when it ran into the back of the leader which was allready on his mains.[X(]
