RE: Welcome to Club SAITO !
Is the header pipe turning to loosen up the assembly, or is the jam nut loosening? Is there room to use aother nut to tighten against the first? Since it has a pretty long moment arm just hanging, can you fit a support bracket to help steady the muffler so it does not shake around?
