RE: After Run Oil???
Use it every time I put my planes in storage for more than a month. I just don't put it in my Carb due to the possibility of it eating away my O-rings, I take the glow plug out and put a few squirts in that way. It keeps the bearings and the crank from rusting and prevents old glow sludge from forming. In the winter I put a little in my glow tank so the sludge doesn't build up in the tank.
And when ever I use a Du-Bro Kwik-Fill instead of a Fuel Dot , once every 2 years I put a little in the valve itself so the spring and valve doesn't start sticking.
Now if you don't have After Run Oil, I head that Mystery Oil does about the same thing that After Run Oil does, and it's a bit cheaper. Matter in fact it smells about the same as I recall.
Pete
