ORIGINAL: OhD
You'd be exceeding the A60 specs if you tried to get the power we typically run with the newer low IR batteries.
Jim,
I've run the A60-16M quite a bit on TP PL V2 5300s, and a limited amount on TP PP30C. Yep....current is way over spec...and it was way over spec on TP PL V1 5300s as well. Bottom line is this.....I've run the A60-20S and A60-16M at well over 3000 watts with zero issues. A number of the regulars on the pattern circuit in the northeast are running various A60s, and when used in pattern applications, they have been extremely reliable.
Regards,
