RE: Anarchy Airboat morning run (pics)
I replaced the plastic tab on the box with a piece of angled aluminum. Now use a nut -n- bolt, rather than a screw into plastic. I managed to get 4 runs today. Stuffed it hard enough to kill the motor once. The other 3 times were high speed flips. Stayed upside down until I used my rescue boat to retrieve the Alligator Tours. At the end of the day, opened the box, no water. I do use a little silicone grease on the foam seal, which also should improve the results. At least that issue is now solved.
