I just use the spellchecker before I post and that clears up those tricky words
On to the CG issue.
Depending on the maker the manual could very well be WRONG! Nitroplanes.com has a few models out that if you were to follow the build manual you would be in for a quick flight resulting in lawn dartage.
How "level" does the horizontal stabilizer and fuselage (another tricky word) look when the plane is resting at CG?
The only info I can find is that the CG is from 3.5" to 3.75" back from the LE.
