RE: Body for D8T
actually the punisher body has been out for a while. I like the bulldog body a little better. but you have to drill (2) more holes in the "front" shock tower so that you can raise the body posts slightly higher, they supply you with a template for hole location, its necassary in order to get the nose to drop down so that the pin holes peek through past the body.
