RE: How to splice a video,also known as open your eyes
install is pretty easy. the 2 manifolds have through holes on all facets and can bolt to anywhere in the lower hull. the easiest method is right to the battery box(drilling required) the gun has one airline that plugs into the manifold port. and the fill inlet requires a hole to be drilled for fitting to top of hull. the fill inlet can be mounted anywhere on the tank as long as there is space to get a propane tank or greengas can nipple to it. the turret ring requires a quick clip of the plastic bar to widen the hole and fit a side line.
a standard fill is 9-10 seconds(straight up propane) and gets about 25-28 high powered shots at 70 degrees. this is dependant on rate of fire and ambient temps. shooting slower than one shot every 2-3 seconds will yeild about 35 shots.
the gun itself is wired to the original hl gun leads and is not polarity sensitive. the elevation wiring and mg wiring is the same. the tracer system wires splice into the headlight wires. we try to bore site the laser as best we can at 25 feet. if there was just more room a gimble mounting system would have been nice.
we want to post a video on how to intstall the system in the near future.
