RE: THE UNOFFICIAL SHOCKWAVE 36 THREAD
I always Flush the engine with WD-40 then use plenty ARO at the end of a day on the pond. The WD-40 flushes out the Fuel and Moisture in the block and the ARO coats everything. The 1way and starter shaft I posted are stock, straight off Dynamites website. If You replace them, I recomend you replace Both at the same time.
