RCU Forums - View Single Post - Help - New to brushless
Old 06-25-2010, 12:53 AM
nick_75au
nick_75au's Avatar
Default RE: Help - New to brushless
Kv is RPM per volt, so a 1000 Kv motor will spin at 1000 RPM at 1 volt, 12000 Rpm at 12 volt, in general higher Kv means more power hungry the motor is as well.
A rough guide ~28mm diameter in or outrunner is fairly close to equivalent in power, a ~36 mm will be a better choice as it will run cooler. You can see in the table the Watts (power each motor can handle)
http://www.alibaba.com/product-gs/21...RS_750SH_.html
link has some specs on 750 motors
top one has a Kv of 415 bottom one has Kv of 1250 so that gives you an equivalent to look for.
you have a couple of ways top approach the selection of a motor as well, you could get a lower Kv motor and feed it with lots of voltage ie 2 to 3 8.4 volt batteries in series which is efficient.
or high Kv which will need a number of batteries in parallel to give reasonable runtime.
Nick
