Hi Ross!
After playing around with one of their 35MHz recievers, I am not much into Weatronic, but: Why the hell do you waste all your channels, if you use a device like the Weatronic that comes with internal mixing? Get your MX-24S, change a few settings and you will end up with 1 or 2 unused channels. Change it from dual elevator to single elevator. Use the internal mix-function to slave the second servo to the elevator-channel. Same with your flaps. Once the flaps are dialed in, you will never touch the servo-settings again (on the field). Now if you are still looking for a couple of free channels, you can set your transmitter to one aileron and get the settigns done via the rx. And it is possible to run the gear-valve and the brake-valve on one channel. Last question: What kind of engine do you use? I have not used two channels to operate a turbine for the last 7 years. That was after JetCat made the switch to a possible 1 channel operation. So what was your problem again?
I hope this helps. I am just dialing-in my Airworld L-39. 2 ailerons, 2 flaps, 2 Elevators, rudder, steering, ECU, ligths, speedbrakes, smoker, gear, gear-doors, brakes. ANd the door-sequencer is programmed in the tx....
Best regards,
David
