RE: Truggy selection after first race..
now when putting the diffs in make sure to use 2 shims on the ones that cross inside the diff on each gear. and then when shimming the diff inside the case make sure to shim it tight, a little notchy.
on setup 40 or 45 all the way around in the shocks
7k front 10K center and 3k rear in the diffs.
