RE: Problem with Zenoah 26 clone
I have some good news! I tried it today. I opened the L needle at 2 3/4 and the H at 1 3/4. I put my finger on the carb to draw fuel and once it did it fired up immediately. I put the rear side in the water (to force resistance at the propeller) and it seemed that the engine was not quiting . I left it inside the water and I started doing circles. The throttle seemed that did not have response ( the servo was moving), so I took it out and close the H needle at 1 1/2. I fired it up again and put it in the water. At the second attempt everything was very good. It had very good throttle response and very very quick accelaration. The only drawback is that the top end is not very good but I think that I must be patient with this. I will first burn a couple of tanks and then I will try to close a little bit more the H needle.
