RE: Pull pull question
Geometry of one of the cranks is deferent than the other. Rudder bellcrank must be aligned to the rudder hinge line. Any miss alignment will cause a slacking of one and tightening of the other. If your cabling at the servo is mounted directly to the servo, you've got perfect alignment unless your bellcrank there is bent or bending under load.
Hope this helps.
Ray W.
