RE: ESM Hawker Typhoon ARF build thread
Oh my ... what a bummer. What prop were you using? You say you were in a slow left turn. Which way did she roll off? Further to the left or did it roll to the right? I was originally running a 20x6 Master Airscrew and it just didnt develope enough airspeed to be comfortable in the turns. It flew but I was totally on edge going around turns thinking I might stall the inside wing. Would that have happened it would have rolled off to the down (inside) wing and snapped into the ground. Maybe thats what happened with yours.
Regardless ... thats such a drag. Sorry to hear it.
Not to be a vulture or anything but I could use your axles out of the landing struts if they are not bent. I bent mine on a poor landing the other day to the point my tires are hitting the struts. I would be happy to purchase them from you if yours are not damaged. I could actually also use the main wheels too if you would like to part with them. Let me know.
Charles
