RE: Kyosho T-33 Shooting Star Motor
Greg,
Will that 69mm E-Flite fan set up be too small for the T-33, if it is to replace the larger stock fan?
Also, did you make improvements to the jet's air intakes by sanding off the inner edges? Did you do any improvements to the thrust ducting?
DryPipe.
