RE: Skybolt hangar and clubhouse
Zor,
I wasn't using mixing but had planned to learn to use the rudder. Do you normally switch it on and off as needed or keep it on all the time? How much rudder do you program in to start. How does it haveing it on affect other maneuvers?
On take off, do you let the tail come up right away or keep it down with elevator?
After a nights sleep and time to think about it I might have kept the tail down to long which kept the plane from gaining airspeed. Also I set my cg on my fingertips. I'm thinking I might be balanced to far forward. Today I'm going to put together a cg sling so to be more acurate on setting it.
Thanks for the help, its taken as intended.
Your name is interesting, is it short for something longer?
Rick
