help is this alright
Should be fine. It will fly faster than you are used to. Don't slow it down on final as much as you do with the trainer. Also on takeoff, don't horse it into the air. Lift it off and climb it slow. Take it up high and learn what it does at different speeds. You should be able to fly it, just don't try new stuff low till you are used to it.
