RE: Contra Rotating Propeller Drive for f3a 2m Pattern Planes
Brenner,
I believe that most setups like this use a higher pitched prop in the rear as the front prop has accelerated the air. What you may have it the rear prop cavitating in the wash from the front prop.
I would try leaving the 2018 up front and the 2020 in the rear.
Good luck, eagerly watching this,
Chuck Hochhalter
