RE: Custom electric boat builders
BACKEMF could build you a boat
I have seen his stuff and it works good
If you have never had an electric your run times are going to be way shorter than your gas stuff
Gas you run till you get board
Electric you run watching the clock
Does not take much to loose track of time and make one pass too many and things get too hot and you will find yourself ordering new parts
Might be better in the long run to spend $500 on a smaller boat to get the hang of electric then to burn up a $500 part first time out
