RE: EV5D-5U-PRO question
Guys,
I posted on a similar thread but i'll do the same here. I posted earlier on this thread about the pressure display on the brake side stopping at 26psi when dumping that system to 0 psi. after sitting in the shop with no pressure for about 3 weeks, the next time I went to fly I powered up the system and the display was back to zero. I filled with air, display came right up, dumped it again went to zero, filled again, flew, landed, it show the pressure drop that I used the brakes, dumped it, went to zero. It's working fine now. Back to normal. I guess it " fixed it self.....[sm=confused.gif] Works great now. Thats my story... I definatly recommend to dump all the air after every flight session ( brakes and retracts ) and use the moisture trap... Good luck !!!!! Great valve for sure, solved ALL my problems with Door issues on my F-16.
Danno
