RE: Aeroworks Extra 300 60-90
You're right da Rock. Let's not imply or impress that this is not a very good airplane. If it is anything like the 540T, it will be very durable. But there is a considerable disappointment that comes with buying something based on information that turns out to be misleading, at best. I can see this model being a real winner, but I'm glad I engaged in these threads before I pulled the trigger and I have no intentions of buying the 300, considering what I am looking for.
Now maybe the 260 is the airframe I should be looking at instead. It seems that the top hatch is set up well for electric and if it is actually lighter by a half-pound at the same wingspan and $10 less, then perhaps this would be the better choice for what I'm looking for. I'll investigate other threads on that model as not to waste anyone's time here and see if it will do the trick with the electric setup I was hoping to install in the 300. If you can tell me your dry weight with the OS61, it would help start me off.
