RE: Super Soprtster Elevator question ?????
Well ithappened again last night and I was not going that fast. May be half speed. I was very high when it happened. I had just taken off and climbed high then pulled up harder and the plane started spinning to the left. When I landed checked out the plane again and noticed I have a slight warp in the left aileron. I am thinking may be the warp is enough to cause this. It is worse at the tip and if I remember right the further out on the wing the more it affects the flight. I will be trying to straighten it out and see how that works out.
