Can the Aurora 9....
Hi, I'm thinking of upgrading my current transmitter because of the programming limitations.
A fellow flyer has an A9 and suggested I consider trying one out.
There are 2 issues I need some clarification on:-
#1 One of my planes has 4 aileron servos (2 aileron servos per wing) I can get this to work on my current transmitter with some convoluted mixing, but I lose the trim in one wing plus the onboard programming for e.g. rudder to aileron mix. Can the A9 support such a setup?
#2 Servo sync/servo grouping. I'm not sure if the A9 has an equivalent feature, but the idea is to be able to do away with either a servo programmer or a matchbox on surfaces which use more than 1 servo (e.g. dual servo elevators) Again, I can work around this with my current transmitter, but I can notice when the travel of the servos are not fully synchronised throughout the movement (and not just at centre/end points).
Thank you.
