RCU Forums - View Single Post - Servo Programmer question
Old 07-12-2010, 10:26 AM
DaddySam
My Feedback: (9)
Default Servo Programmer question
I have one of the new servo programmers that can interface with the PC or be used as a field unit. I was learning the software and had a question. Sometimes when I attach a servo arm it will not be right at 90 degrees to the case, so I was planning on setting the center point. When I do this it wants me to set left and right end points. It seems like one side will be a number like 84 and the other will be much greater. When I then cylce the servo in the test mode, it will swing way to one side and less to the other. So my question is, if I set the center point, what value do I want to set the endpoints at? Do I want to set them both to the same number on either side of center?
Thanks for any assistance. I'm programming some 5645's.
Sam
