RCU Forums - View Single Post - Has MonoKote formulation been changed?
Old 07-14-2010 | 09:15 AM
  #203
Airplanes400's Avatar
Airplanes400
My Feedback: (349)
Default RE: Has MonoKote formulation been changed?
In short, yes, monokote has changed ... and for the worse. They went to an environmentaly safe formula years ago. That ruined their quality and characteristics. Also, monokote now streches further length-wise as opposed to width-wise of the roll. This becomes noticable if you cover your ribbed wing in different directions (90 degrees) from each other. If you cover your wing length-wise of the roll, the concaves between the ribs will be more predominent (this is bad) than if you used the monokote in a width-wise direction.
