RE: gws esc ics 300li issues please help
On some TX's (Futaba is one) you have to reverse the throttle channel servo switch on the TX for the ESC to work, also make sure the lead that goes to the RX is in the right port for the throttle. On all of them I have used I center the trim on the throttle, plug in the battery at min. throttle then go to full throttle, wait for a coup[le of seconds then go full off throttle and then advance it and it should then work. Sets up the ESC to the Throttle travel I guess.
Please remove the prop when you set it up as I have some just take off when I have reversed the servo switch.....Be Carefull !!!!!!!
Hope it works for you
Bob
