RE: E-flite F-86 Sabre 15 DF ARF
The Spektrum AR6200 receivers were placed in the locations and orientations per the manual using the supplied hook and loop material. I also secured the ESC in place using some of the supplied hook and loop material and my own 3M Velcro black strap. Additionally, I glued the four corners of the ESC to the fiberglass bottom with small dabs of epoxy that could be broken away, if needed.
The fiberglass intake tube was fitted into position after first surrounding the center with a hook and loop strap. The strap is put on first so that it doesn't accidentally get wrapped around the steering rod later on.
