RE: After three years...
If you didn't run it completely out of fuel before you put it away, you'll wanna change the fuel lines, take the carb off, disassemble the carb and the engine and blast 'em with nitro cleaner. When fuel sits in an engine, the alcohol evaporates leaving behind just the castor oil and it gums up everything.
