ORIGINAL: diabolic-mind
its possible it just had a faulty battery from the start. i recently got a new flyzone playmate and the motor in it overheated and melted the motor mount on the first flight. the cause of the issue ended up being the cap on the end of the motor was loose. something similar could have happened to your motor overtime. or maybe the brushes wore out in it.
Hi, No it was not the battery, I had used several different batteries, Not sure why it has worn and failed so quickly... I understand a small motor will not last forever but 2 weeks???
