OS91FS loose front bearing
I have an OS 91 FS Surpass II which runs beautifully, nice idle, smooth transition and generally very reliable. Its had a lot of use now and the front bearing is a bit loose in the housing (bearing itself is ok) resulting in a bit of lateral prop shaft movement and hence vibration generally resulting in me losing prop nut mounted Al spinners (expensive!)
I have tried Loctite and shimming but these only seem last a couple of flights before the bearing is once oagain spinning in the crankcase housing and the lateral movement and vibration returns.
Apart from buying another crankcase, can anyone suggest a longer lasting fix?
