Aurora 9 and servo jitter
I just put my new Aurora 9 into a 30% Extra 300 using 2 Hitec 645 servos for the elevator halves. I am using the 9 channel optima reciever and a 3300 mah 6 volt battery. Everything is fully charged and everything but the elevators work correctly. I have 1 servo plugged into channel 2 and the other into channel 8 if I move the sticks every once in a while one servo will fully deflect in the opposite direction and then work properly for awhile and then go nuts again. It worked fine with my Futaba 9c any ideas as to why this might be happening thanks for the help
