RCU Forums - View Single Post - Tail Wheel Idea ?
Old 08-05-2010 | 09:03 PM
  #40
rc airplane nut's Avatar
rc airplane nut
Default RE: Tail Wheel Idea ?
ORIGINAL: RCKen
Install a Sullivan Tailwheel. I mounts on the bottom of the fuselage and has a spring that extends out to the rudder and inserts into the wood on the bottom of the rudder. This will give you a steering tailwheel.
These are the tailwheels that I prefer because the spring isolates the rudder from the tailwheel in case the wheel is jammed or jerked to the sides. It prevents damage to the rudder.
http://www3.towerhobbies.com/cgi-bin...&I=LXFV47&P=ML
Ken</p>
