ORIGINAL: tandem4
After a long lay off ...... since September last year when we moved from Angola to South Africa and then beginning of the year to Nigeria the Blade 400 is flying again!!!!!! It is rainy season here and inbetween tropical rains storms I mananged to get her up into the air a few minutes ago. A few short nerevous hops and then!!!!!!...... I managed a low level very unsteady hover for thirty seconds. Then the rain came again!!!!!!!
While in South Africa it was hectic and I had the mSR to play with, I never toueched the Blade. Then we moved to Nigeria and with our first home leave in May I brought the Blade here. I totally stripped her, servicing bearings with my new Greaser, reassembled and then set up....... and she flies!!!!!!! I need to balance the tail, do tracking, balance the main blades ...... but she flies!!!!!!!!
tandem4,
Well it looks like you have been through lately with all of that moving and bad weather. But at least your set and now can fly a bit. I am glad you like the "Greaser" too. Once a year on each bearing or a new bearing install and I have "never" had one fail, it is worth its weight in gold.
Good Luck JPEE
