ORIGINAL: tornad0
sec if the mini cat is B2848-2636kv water–cooled brushless so its 380
in my apparition ther are two of 380 2881kv Water cooled Brushless
they are the same sized motors?
the apparition is with higher KV so its running faster then the minicat on same battery's?
i have a dry box on the tunnel the distance between the battery's and the hatch is 5mm
the boat is handling very good at any conditions
setup has a lot to do with top speed
