ORIGINAL: Campgems
I've flown two 4*60s with a Magnum 91 four stroke. My prop of choice was an APC 14x4W. You could lift off a go near vertical with that setup. The plane weighed in at around 9 lbs, including a half pound of nose weight. I would think more power would not be much better and could lead to some evil ground handling issues. I've got a Twist 150 with a Saito 180 in it and it is really way to much power. I know, there is a throttle stick in the TX, but my tendency is to get up flight speed then go full throttle before lift off. With the Twist, and a couple other over powered planes, that has presented quite a problem.
Don
You big girl, I have an idea or two for that 180!!!!
It's big and long, pink purple and white. ??????? Kinda sounds girlie doesn't it!!!!![&o] Just tested an APC 15X8 and plan on trying the 15X6 next time out. Road trip to NICE this week for stuff.
