ORIGINAL: BarracudaHockey
You can't use a Y harness with a V tail or the nose wheel will move when you give elevator.
You can:
A. Use a separate servo, hooked to an aux channel, and P-Mixed with the rudder
B. Take a pushrod off the oppostite side of one of the V-Tail servos.
Andy, how is option B going to work. you would get stearing movement with elevator movement wouldn't you?
Don
