RE: Nise Wheel Steering With V Tail Mixing?
I ran one pull-pull cable from each 'elevator' horn. The cable was routed back into the fuse to the tailwheel tiller. The tailwheel had horns or tiller each side of pivot. Each pull-pull cable had a spring attached and springs were attached to each end of tiller. Down and up elevator input created equal tension (more and less, equally- depending on which side the horns are mounted) from springs but rudder input created differential movement. Hope this makes sense.
