Vertigo Performance have released our clipless/boltless front axle extenders. We have had this product in use for nearly 2 years and finally have them available to the public.
Some things that set Vertigo Extenders apart from others on the market:
Design? - We are the only company to produce an extender that has options of narrow or wide stance so you can tune your front end for the track within seconds.
Clips? - PFT!!!! No clips here!!
Bolts? - What bolts? who uses bolts? not Vertigo, not when they can break and get stuck in your hubs.
Price? - Better than the competitor
Originality? As with the majority of our product line our axles extenders are just another product we have put into the market place before the competitor.
If you want to go clipless and don't want to go wider our axles work with stock rear hubs to retain the stock width on the front of your HPI Baja
When you are Bashing you may want a wider stance, racing you may not have the turn in you need with the wider stance so you can, within just a few seconds take your front end from wide to narrow by using any stock style rear hub on Vertigo Boltless/Clipless shafts.
Kit includes:
2 - Hollowed steel flanged shafts
2 - 8mm Extended hubs (the same hubs we have sold thousands of for the rear of the HPI Baja)
2 - 4x24 Hardened Chromed European made steel pins
2 - Rubber retaining rings
Check out
www.vertigoperformance.com
