RE: Need throttle curve help on gasser
The first thing to do is lengthen the carb arm to match the servo arm so they move the same. The little short carb arms will really complicate setting up linkages. Then use the curve for the final setup. I tap the holes in the carb arm to 4-40 or just bolt a piece of fiberglas, etc. thru the hole in the arm. You can also offset the arm that way for better geometry.
