RE: Servo Strength's
Well about the C/G with the bird in the vanessa rig and stablethe (book calls for C/G @ 5 1/4 back from the L/E at the fuse, mine is @ 4 7/8 plus 1/2 of the tank is fwd of the c/g
About flying loops are a bit tight if you just jam fuul up, probabley 50 ft. dia when you fly it thrugh you camake them as big as you want and they do repeat. Landings are a breese stall or wheel.
It will be sunday befor I can try any of the suggestions, so the plan is
reduce the expo first
Then add stick on weights (will try 2 oz ant a time)
One outher thing from the book control movment chart on the ailerons about 70 % , rudder 100 % elevators 25 % trying to make a 3D bird into a mild sunday/sport flyer do to the arthritic
and agine THANKS for all of the input
Cheers Bob T
