Old 08-21-2010, 01:29 PM
JohnBuckner
JohnBuckner's Avatar
Default RE: parkzone wild cat
If the model is the F4F Wildcat then that would explain the difficulty in balancing. The Wildcat was a true mid wing aircraft and this make balancing much more of a challange simply because the midwing does not have added static stability like a low wing would balancing inverted or a high wing being balanced upright.
Many of the midwing sport aerobatic types also a bit more persnickety on the balance stand. I agree with Villa it sounds like you close enough with the lead installed.
John
