RE: Prop Balancing Question
Don't sand it. My preferred method of balancing a wooden prop is to spray light coats of clear poly-u on the front of the light blade. Unless it's drastically OOB, one or two coats will do it. Sanding the prop may cut through the thin coat of varnish, leaving the prop exposed to the elements, dirt, and fuel.
