RE: Throttle flutter with motor running, radio on
For what it's worth the flutter/jitter occured at idle or attempted idle. It seemed to to clear up at increased RPM to non existent.
I haven't had a chance to run the new set up yet and I will report back on using the Dubro ball link set .
The plane is an old timer, Brooklyn Dodger , with the affected servo up front just behind the the fire wall in a sort of pylon with the receiver and battery seperated by another bulkhead and rudder& elevator servos way back towards the tail. The motor is a Magnum 32 ,2stroke. .
Reading repelies, I see mention of many bad conditions.
Thanks guys
