What does your Funtana 40 weigh?
5 Pounds, 9 ounces, with a Saito 72, SlimLine pitts style exhaust, , Aluminum spinner, remote glow driver, and remote fuel filler.
Using S3004 servos, with CF push rods, and a 1450 mah battery located in a CF rack under the wing hold down brace to off set all the extra metal in the nose. I also added some plywood to triple the thickness the front dowel holes since I noticed some wear on the dowels after engine break in/ run up tests. I hope to maiden the thing this week if I can sneak away.
