RCU Forums - View Single Post - Telmaster wing struts
Old 09-07-2010 | 10:32 AM
vmsguy
Default RE: Telmaster wing struts
I thought I'd add my $0.02 with reguards to struts.
Others have pretty much summed it up. Struts are probably a good idea, and heck, they can't hurt. If you opt for a two-piece wing, probably a darn good idea.
Here's what I settled on. I originally thought of using sticks of spruce, but found some aluminum tubing instead.
I pulled out my electrical plyers (sometimes called lineman's pliers) They much heavier then regular pliers, and you'll often seeing electricians use them almost exclusively. Anyhoo, The pliers were big/strong enough to squeeze the end of the tubing flat, then folded it over for a little more strength, and then drilled holes.
On the mount point, I drilled an extra hole in the pin, and used an extra spring clip to hold the pin in place. Now, it's really easy; pull one clip at each end of the strut, and it comes away quickly. And I don't run the risk of loosing the pin.
Plus the aluminum is a little thinner and cleaner looking than the wood struts would've been.
ID:	1496851   Click image for larger version
