RCU Forums - View Single Post - TWist 40 covering
Old 09-11-2010, 08:53 PM
mikegordon10
mikegordon10's Avatar
Default RE: TWist 40 covering
If you use the heat gun be careful around the edges. I use a piece of card stock to shield the edges so they don't loosen with the heat. Other than that it shrinks up nice and tight, If you need to shrink it up around the edges use either a trim iron (my favorite) or a covering iron with a sock on it.
